its an unusual clunking from the rear end. In the corvette magazine i have there is one guy that has the same symptom with his but its a c5. They say the noise stops when they straighten up and drive away. The tech nerd says when it gets colder outside the viscosity of the oil and the ever so slightly shrinkage of the parts changes the clearance between components. They say the clunking is from the limited slip friction plates and the noise does not indicate a problem. don't know if i should get it checked out at the dealer?could you describe the noise?
There is also a known issue with rear end noise in C6's but I was under the impression it was fixed for the '07 model year.
Nope, more like a clunking noiseMarbles in a can?
thanks, im thinking of getting all the oils changed in the car. do you recomend a certain brand? some guys say mobil 1 for motor oil others say royal purple for tranny and diff oil??? my best friend has a 2010 camaro ss and on his forum they don't like royal purple but i think it's the motor oil. not sure what to put in, one thing i know its gonna be all syntheticyup, thats one of the known issues with the c5/c6 diff. change the fluid and all should be well. i recommend either redline or royal purple fluids.
any idea on what oil weight to put in the diff?thanks, im thinking of getting all the oils changed in the car. do you recomend a certain brand? some guys say mobil 1 for motor oil others say royal purple for tranny and diff oil??? my best friend has a 2010 camaro ss and on his forum they don't like royal purple but i think it's the motor oil. not sure what to put in, one thing i know its gonna be all synthetic
right on...thanks, i will do that. mine is still on warrantyJust had the same prob with my 08' If itS still under warranty (mine was) take it to dealer and they will replace with correct fluid. It is known prob from fRom factory.
