I recently purchased a '95 LT1 convertible and during normal stopping (no panic stops or slippery situations) the ABS activates 80% of the time. The "Service ABS" light is never on but does work. Any suggestions? Is there a sensitivity adjustment?
· Premium Member
There is no sensitivity adjustment. The ABS depends on inputs from each wheel speed sensor to determine that it needs to pulse one or more wheels.
I'm assuming that you're feeling some kind of pulse in the pedal most of the time (80% by your estimate if I read correctly), which is why you're assuming that it's the ABS pulse.
It might be an errant wheel speed sensor, but I'd pull the wheels, check pad condition, and measure rotor runout to make sure that what you're feeling is an ABS pulse as opposed to a rotor with thickness variation.
Steven
BTW - Welcome to DC!
PS - I lived in Dallas, GA from 1989 - 1992! It sure has grown - it was still a pretty sleepy little place when we left for Illinois.
· Premium Member
It's definitely the ABS kicking in - the "ABS Active" light comes on, I can hear the pump working and can feel it in the pedal.
OK - do you have a factory service manual? You'll need that to begin the troubleshooting steps. If you don't have one, you can find the one for your '95 directly from Helm here
http://www.digitalcorvettes.com/forums/showthread.php?t=61402
or search on eBay. Knowing the cost of the Helm unit will give you some insight on how much to pay on eBay.
Steven
· Valued Member
the same happens with my 98 windstar van the abs doesnt come on but when i am slowing down to a stop i here the grinding my mechanic said he would have to diagnost the van check every sensor should i even worry about it , just makes a little noise van stops no problem didnt want to steal your post but figured kill 2 birds with one stone since you were on the subject sorry.
