I have a 2003 c5 and it has developed a small oil leak. Usually a drop or two on the floor of garage. Sensors seem fine oil pressure is fine. looks like it is coming from oil pan.
God I love this site :thumbsup:Maybe it's bubbling up through the ground????
You ARE in Texas! :thumbsup:
Here I am trying to make the OP some money, and you start creating projects! :spanked:Seriously, on the LS motors, oil leaks seem either
really simple like:
Oil filter not tight
Oil drain plug seal bad
Oil cooler fitting loose
Faulty oil pressure switch
Or really not fun like:
Oil pan gasket bad
Rear seal failure
Front seal
Head gasket
