Have you checked the calibration of your stock, electrical gauge and it's signal? Have you verified what you believe it's reading with a known mechanical gauge? Have it's readings changed suddenly as of late? As a very general rule of thumb and assuming a system of adequate capacity, flow and drain-back for it's intended purpose, 10 PSI per 1000 RPM is adequate. High oil pressure numbers are generally equated with a healthy engine. All things considered, anymore pressure than needed is a parasitic drain on power and an unnecessary load (and stress) on the pump drive parts. I realize this is likely an over-explanation of the question at hand. But the reason is to emphasize among other things, that readings, especially those from an unverified gauge should be taken with a grain of salt. And once accurate readings are verified or otherwise obtained and matched against spec minimums, only then should you be concerned.
