hi all
my oil pressure gauge started to do funny things....
shows normal oil pressure, than suddenly jumps way over , then goes back, repeating this behavior randomly...and sometimes, it shows correct pressure, increases with rpm and stays at a maximum of 60psi...and work like it should...
i suspect the oil pressure sensor/switch and its harness....the cables are under some tension, because they are real short ...
i also knocked on the dash, no reaction..
would you agree?
any tricks for changing the sensor/switch?
would AIRTEX Part # 1S6592 work?
thank you
would you agree?
thank you
