I have gone through so many different ideas, and so many half started projects, I really need a clean start.
Lets think about what I have and what I can do with them, and the direction I want to go in.
This is a brain storming session, so there is no stupid ideas
1.) I have a 1996 truck block with 4 bolt mains
2.) The OE roller lifters, spider and little retainers.
3.) AFR Hydra-Rev Kit
4.) Superflow 195cc heads, ported
5.) Ferrea comp 6000 2.02/1.6 valves
6.) GM Springs (.54 lift) +retainers+locks
7.) Titan Oil Pump
8.) Custom billet oil pan
9.) OE truck windage tray
10.) Holley 750 4150 DP carb, most of the way modified for blow through
11.) 2x Dellorto DHLA 40H carbs from a Lotus and the 4-barrell adapter
12.) Fluidampr
13.) LPE 213/219 cam
14.) 288(236)/300(248) .536/.536 with 1.6 ratio rockers 112 LSA 4 degrees of advance
15.) Weiand Xcelerator 7547 intake
16.) Chinese 2.5" ram horn knock offs
17.) Racepump 150psi pump and the matching regulator.
What I need to do is be able to cruise at 65mph at 2500 rpm with a keisler 5-speed with the racing .82 final gear and 3.73 rear gear.
383ci using my intake, heads, cam, ramhorns, my dellortos, and all the little surrounding parts. I will need to get some pistons made up, as I think I will need 7cc pistons. KB does make a set.
Lets hear some ideas.
7.) Titan Oil Pump
12.) Fluidampr
