Problemo....taking my TPI oval intake up and over top of radiator....allready cut support, and hood is modded allready, have 3.5 inch induction setup allready....so....need a oval duct ~3" high, 4.5" wide, and down to about 3.5 inches round on front end...make it 18" long..... ~45* down angle....
what/where/how/how much....
aluminum tubing is out....not easily available...need tig welding anyway....
rubber hose....?? any other suggestions, except a junkyard raid....
cheeeeeeeper is better as always.....but it's gotta get DONE.....
Hmm, maybe heat forming a piece of 6" PVC Pipe, say in a saw box?
TPI oval needs 4 inch id hose. You could get a 4" to 3.5" hump coupler to isolate the vibration and allow you to bend. Use a aluminum tube squished down or fab stainless as
TT suggests then a 45* coupler to where ever....
DR Gas sells steel oval pipe and transitions
http://www.ovaltubing.com/
Boost Controller has hump hoses and reducers....
http://www.boostcontroller.com/index.php?category=34
:devil:
:devil:
I say THANKS you ALL very much for the suggestions....and it was getting down to fabbing something....BUT it looks for evermore like the boostcontroller.com link there has the tubing I need modd a little bit to fit....
should work, I THINK.....
tmrw is another day, and I reserve the right to be rong.....
