you need a OB2 code reader with check egine light erase function or someone who has one.I have seen them on ebay for $40 and you can use it on all your vehicles that are OB 2 compatible.
lolartyon: , got that coverd, but it keeps coming back on, I am thinking my air pump may be bad or simply not working for whatever reason. I'm gunna check it tonight and I'll let you all know what happens.
i had this exact same problem, i found a solution to it on another board, look under your battery tray and check the vacuum hoses under the batery. one of the hose got corroded from leaking battery acid. i will try and find the article later today.
