DANG!!! A new trivia question!!!BubbleHead said:I never realized there wasn't a key hole on the passenger side. Interesting.
Yes it was 2000ragvette said:Found the info, it was removed in 2000 and above.
Thanks Truck Guy.Truck Guy said:Yes it was 2000
Are you serious about the weight savings????stilcrazee said:Done for cost and weight savings. Europe lead the way with this idea.
3/4 of a pound? Why not remove the C5's HUGE ass?stilcrazee said:Tim,
You know what biz I am in. that's what we were told back when it started. Not only the lock cyl, but the rods too, may only equate to 3/4 of a pound but trying to make epa mpg requirements made anything fair game.
Actually, the huge ass was designed in from the beginning for the factory racing program. It produces what is called the "Kamm effect" (named after the German automotive engineer who discovered the principle). If you remember back to the Porsche 917k and Porsche 917LH you'll recall that although the LH (for Lang Heck or long tail) was faster down the Mulsanne straight than the 917k (k for kurz or short tail) it was unstable. But the high, straight drop rear of the 917k produced better aerodynamic stability. Corvette wanted a car that could compete at Le Mans and be stable on the long straights. So the design guys were persuaded to make that huge rear-fascia that I hated until I actually spoke with the Corvette racing engineers at Laguna Seca and found out that it is actually functional (albeit at very high speeds). In order to be homologated for the ACO GTS class, the race car has to use body panels shaped like the production car.Patrick96LT4 said:3/4 of a pound? Why not remove the C5's HUGE ass?![]()
So...if I read this correctly....are you saying you are fond of fat asses??RT66Z06 said:
I have since developed a fondness for the Bauhaus design of the rear-fascia.
Ray
i surely am if they have over 405 horses in front of themstilcrazee said:So...if I read this correctly....are you saying you are fond of fat asses??![]()
Not fat, huge. There's a difference.stilcrazee said:So...if I read this correctly....are you saying you are fond of fat asses??![]()
You guys are cracking me up!RT66Z06 said:Not fat, huge. There's a difference.
Ray
Last one first. The rear-end shape has more to do with directional stability than down-force which is what a wing provides. That's why the C5-R has a rather large wing.Patrick96LT4 said:I actually never knew that it was really needed for high-speed stability. Do you think we'll see the same larger rear on the C6?
Wouldn't a small wing-lip on the back do the same thing as the larger rear?
