I have approximately 10K on the car and I am noticing an engine noise that has me baffled. Baffled because I can't diagnose it and it changes in intensity.
Sometimes when I start the car it makes what sounds like a deep knock and I think: main bearing (gulp). As I drive the sound seems to max as you cross about 23-2700rpm with light load; actually, the lighter the load and the cooler the engine, the louder it seems to be. With a heavy load from a hill or from more throttle the sound is all but inaudible. It actually sounds like a lifter a bit out of adjustment. As the car gets hot the noise subsides to hardly noticable.
My inclination is to just beat the piss out of it and if it breaks - - it breaks.
A few have mentioned piston slap but I have never really heard this and was wondering if this is what it could be or if it is something more ominous.
Oh, I have listened with a stethascope and just the usual mechanical noises - - I suppose what is un-nerving is that it never used to make this noise at all and this make me think very bad things like bearing going south on me.
All comments appreciated.
Check for a small crack at the header flange. That might close up with heat or be lost in the motor sounds under throttle?? If it subsides with heat it must ba a small crack somewhere:huh:
Just a guess.
This was my first thought and I changed the gaskets back to steel and I examined the head for signs of carbon: none.. I know that a loose bole or a small leak can mimic darn near every major problem.
I have an 05 that has the same issue that a Chev svc mgr said was piston slap, "nature of the beast", in addition there is a pinging at low speed take off particularly when going up inclines.
Discussion Starter #5
If it gets hotter and the noise diminishes or goes away -mostly- it's piston slap.
You should notice that it is most pronounced under little or no load but under load it is not present . .
