Hello guys need help ,how on a canadian model 2000 i disengage the twilight sentinel for my headlight to popup some body told me maybe you need to take of a fuse ???????????????:
regard and have e good day everyone::buhbye:
Cuvette (Montreal,Canada
On Canadian equipped Vette the twilight sentinel is standard. I am not 100% sure but I think if you pull fuse #44 it will disable it or you could try and disable it buy cycling through the options button on the DIC if that is available on Can.Vettes. A GM dealer can also disable it by using TECH2. Lastly you can install a resistor in teh harness to fool the system into thinking that it is light out all the time. The sensor is located in the center of the dash at the base of the windshield in the vent that is about 3" x 12". It is the sensor on the drivers side. Hope this helps
