I have a power steering leak. It appears to be coming out of the fitting on the control valve. I tightened the fitting, but there is still a leak small leak
How tight should I make it?
Is is possible that the fitting is bad and needs replacement?
Pull the line out and look at the flare vary carefully. Bet there's a crack in part of the fitting/flare.
