:agree:I shouldn't take awhile to circulate you might have messed up your pump.
:agree: good call I didn't think of that.:thumbsup:Air may have mixed with your fluid when it was low. Check your fluid level again, if it is low fill the reservoir to the proper level, run your engine for a few seconds while turning the steering wheel from lock to lock several times, shut off the engine and add fluid if you need to. Maybe driving it wasn't enough to purge the system of air. Hope this helps!
