I would think so, although I obviously haven't ever done this.
Pretty sure those plates in the tips are why Corsa's don't have any resonance. Can you put them back in if you don't like it without them ?
Only reason I ask is if you ever wanted to sell the Corsa.
Maybe you should consider going to the B&B if you want a louder exhaust?
Another option may be to get an Xpipe to replace the resonator.
It was more curiousity than anything. I am going to go out this weekend and listen to the long-tubes with the B&B exhaust and see if I can tolerate it....
Patrick96LT4 said:
What will happen if I punch out the "dummy" holes in the C4 Corsa exhaust?
Will it get louder? Just curious...
you would get all that resonance that is not currently there..
Another thought.. Find out the DIA of the B&B tips..
Ask if you could plug one on each side (The hardware store sells a rubber piece with 2 washers and a bolt.. not sure the name that could plug one outlet) this may reduce resonance while driving around
