Just a thought on MTI front chin spoiler / front splitter before I attempt to install mine. It adds about 30mm to the front. I now have a hard time clearing the slightest driveways in my ls7 without the carbon fiber chin spoiler on, seems like I need jut a few more mm of height to clear. In order to clear my driveway I will need wheels to raise the car 1.3 inches (about 33mm higher all around. Michelin Pilot PS2 285/35/19 and 335/30/20 will do this. The wheel gap will decrease, while my center gravity will suffer. Sucks from a performance standpoint because anytime you raise your car from oem spec you get more body roll. Not only will I lose performance from my wheel upgrade due to weight and size needed for clearance, but now handling will be worse than an oem c5z. If you purchase the bottom cover with the front chin than you will need a cold air induction system that you can cut the radiator shroud to allow air in. The factory z06 has an open slot where air would usually pull in, the MTI carbon fiber bottom cover just seals it.
Pros:
Looks killer.
Downforce if you race at speeds of 100MPH or over.
Cons:
Expensive for quality.
Pits in clearcoat.
Flat surfaces not smooth.
Hard to wax since pits allow wax to dry in pockets.
Needs to be drilled to install.
No template or instructions to install.
Comes in a a heavy wood box which isnt needed and adds to shipping cost.
Adds 30mm to the front which is over an inch.
Now that I have given you insight on the spoiler if anyone would like to buy it off me I will sell it for $950 shipped. I paid $1100 shipped and it is never installed brand new. I have good feedback on ebay so if anyone wants this I can set up a ebay auction for the item to be bought. PM or leave a msg here. If no one buys it by 30 days I will install it.
:smack
Pros:
Looks killer.
Cons:
Pits in clearcoat.
:smack
