Gave it the 1/4 turn. Can't get it out.
I want to change out the coolant, it's long over due.
'04 Z06 80,000 miles.
This will be the first coolant change.
Thanks for any help.
I was thinking about the same thing about my '04 too. If you find out any little secret let me know
The drain plug has a small metal pin at the 3 o'clock position that is in a small groove to a slot. Turn counter-clockwise a quarter turn to line the pin up with the slot. I then used a small screwdriver to get it started and it popped right out.
Drain.
Fill with distilled water.
Run up to temp.
Cool down.
.....I repeated drain refill 3 times, until it ran clear.
Dex-cool and distilled water 50/50 mix.
Car runs 10-15 degrees cooler.
It always sucks when you have to sell your customer a new radiator because the drain wont seal and it wasn't leaking when it came in. I am pretty sure most techs in the field will say they just pull the lower rad hose to drain the cooling system. I sure know that's what I do. especially on the plastic stuff.
