1 - 14 of 14 Posts
I have a 1991 vette with a aftermarket radio. It has been working fine until yesterday, i turned off the ignition and opened the door then the radio turned off like it is supossed to. When I got back in and started the car the radio will not come on. I checked the pink acc. wire that powers the radio and there is no juice. just wondering if there is a switch,relay,or module that turns off the radio when you open the door. if so where is it located.please help. thanks jay
Did you check the fuses for the radio? There is one radio fuse in the main fuse block that has battery voltage (orange wire) and another radio fuse in the auxiliary fuse block #2 (yellow wire) that has ignition voltage. Both these wires go to the solid state radio receiver box.
Is there power at the yellow wire? Did you check any circuits with a test light or did you visually inspect them? If the latter, check the yellow and orange circuits with a test light and see if there is power there. In that diagram, it shows the radio receiver box, there should be a conncector on the back side with all the circuits going to it.
Okay, since the yellow wire is hot, your delayed accessory bus (retained accessory power) relay is good. The problem is further down the line. You need to check the ground at the radio receiver box. Connect your meter to the orange or yellow wire and black ground wire at the radio receiver box to make sure the ground is good. 12V
I'm wondering if the acc power wire is fused on the radio harness. It's not that common, but my Pioneer had both power wires connected to in-line fuses. Just a thought.
1 - 14 of 14 Posts
