Hi to Patrick
Don from CT here, on the way home from Carlisle my radio cut out and would not work at, all clock was on but no radio. This am went out to car and
the radio worked. We drove home with the air on high wondering if
any one has had the same problem
Donald Ahern
Discussion Starter · #2 ·
Took the car back to dealer to have oil change and service bulletin on rear end lub and have auto trunk release fixed, did all and overnighting a new radio car should be ready this afternoon. Maybe my opion will change about my Dealer (crowley of ct). Will update later
Donald,
My radio goes out intermittantly also in my 06 vert. I can usually "cure" it by killing the engine and opening the door, then closing and restarting. It's kinda glitchy, but that has worked 100% of the time as far as a fix goes. This seems to occur when the car has been exited and at some point in time the person with the FOB that was not used to drive and exit the last time goes into the car and retrieves something from the passenger side door or trunk. Like I said....glitchy! Did the dealer replace yours? How did that go? Did that eliminate the problem? Thanks!:thumbsup:
radio replaced
Ordered overnight new radio was replaced. So far so good
see what happens. This was the second problem with the radio so finally
the dealer stepped up andreplaced it. Thanks for the info
