Its not hard, really. Just jack her up, take wheel off, break loose the 38mm spindle nut. Then disconnect u joints on half shaft next to Dana 36/44 rearend. Then loosen and take off the camber bar on the side next to spindle (closest to wheel, and this will prevent you needing a realignment). Take off brake caliper, and then take off rotor) Then loosen and take out the bolts holding the hub in). SLide the half shaft out and it will bring out the hole hub out towards the rear.
I am doing this off of memory. The half shaft can be disconnected from the hub once out.
Hope this helps. Steve
