I read a few posts about sound proofing the trunk area of our cars
with Dynamat/Fatmat etc or using sticky foam duct/pipe insulation.
Was getting tired of yelling at the person beside me to have a
normal conversation so decided to try it myself.
I removed all the carpet and lining from the trunk area and then actually
drove the car around for a day to hear where most of the noise was coming
from. These areas I found where targeted with additional layers of Fatmat
and foam padding.
I was going to line the trunk with Dynamat (as used before) and then
found the cost was too much so I located the 1/8 foam padding at Rona
instead. Then searching thru Ebay found a place in Oakville that sells
Fatmat in bulk at a cheap price so decided to pick up 100sq/ft of it.
Now having a pile of foam padding and also a pile of Fatmat I decided
to line the trunk area with Fatmat and then put the foam padding overtop
of the Fatmat too. This was a best of both worlds in sound insulation.
Here is a photo of my 99 Z51 trunk area with all carpeting and lining removed.
Now with the Fatmat installed after 4+ hours of rolling.
If you notice the back wall I already applied the foam padding on top of the Fatmat.
I wish they did not put so much ink/logos on the material as my hands where blue!
Final photo of the Fatmat and foam padding installed overtop of it.
Final notes, I added a double coating of Fatmat over the wheel wells top and side.
I added double coatings of Fatmat on the back trunk wall area and double foam padding
as the trunk wall liner would still fit properly.
The difference from this moddification is amazing the back of the car
is dead quiet from road noise yet you can still hear the growl of the
exhaust. Now what I need to do next is the front car area under the
seats and the doors. I will save that for another weekend.
and foam padding.
