My rear lite's and side marker's are out , no brake lite's and went I turn my alarm on it goes off. I check all fuse's and one rear tail lite and all was ok. Need's some imforation on how to fix.
I've had the same problem and found the weatherpack connector behind the left rear wheel had a bad connection on the ground(black) wire, the wire was loose inside the connector. try unplugging the connector and reconnecting it . You don't have the Euro taillamps do you ? Good Luck Ed
