I was driving my 05 down the road, normal, dry conditions, and the car bogged way down said "reduce engine power and service traction control" Now the car doesn't want to move. I was woundering if anyone has an idea about this. Also would the recall in the sterring column be part of this problem. Thanks for any advice.
No the steering is not an issue leading to that problem, you wil need to check your traction control sensors, its very easy with a ohs tool, one of your sensor is bad.
