2000 C5, ran fine past two days. When I try to start it today, it won't even crank. The dash lights come on and give me the following alerts: reduced engine power, check tire pressure sensor, low fuel (even though the gauge shows 3/4), service engine soon.
I don't have a way to get codes from home.
I just replaced the battery, but I do notice corrosive build-up on the + terminal.
Measured 12.2 volts at battery terminals with volt meter
Dash gauge reads battery 11.8 volts
I checked the fuses under the dash
When I went to check the fuses under the dash, I noticed the passenger floor was soaking wet. I did not drive the car in the rain. Could this be from AC?
Any help?
Any help?
