Hello everyone, just joined today. Just purchased a 2008 convertible. The learn feature does not work using the trunk key lock 5x method. I have the driver window down, glove box open, trunk open. I turn the key and nothing happens. Also, I notice the tiny yellow wire running through the rear trunk compartment was cut above the fender well.
When I start the car, my DIC name doesn't appear until I hit memory 1 button. I only have one key fob that is #1. The fob housing is cracked.
I want to purchase new fobs and train them, but the learn feature does not appear to be working.
Any help will be appreciated.
Bobby
I went through the same situation as you. The key didn't work. There were some problems with the system. However, it is from 2008 and should be a little refreshed. I don't know what the steps would be to fix the problem yourself, but I recommend using a locksmith. Why? Because they are specialists in this field, they will immediately tell you what the problem is and solve it quickly and very qualitatively. Besides, you will save a lot of time. I turned to the locksmiths from a company from my country. Do not hesitate to look for a good locksmith.
