LG Motorsports is proud to relase our two piece brake rotors for the Corvette Z06 and GrandSport.
These HD units are a direct replacement for the factory drilled rotors. They use 32 directional vanes for optimum cooling. The hats are made from aluminum for reduced weight. The entire assembly comes in at just under 19lbs so you are saving weight as well!
MSRP $799, check with your local dealer for details.
Limited numbers in stock now, with a full shipment on the way.
