1 - 19 of 19 Posts
Has anyone ever installed a removable window in a 74 or like model? If so was it hard to do?
Curtis74 did this conversion on his car,with the help of "him we can not mention" do a search,i'm sure it was either here or there.
Step 1. take masking take and put large "X" in center or rear window
Step 2. put on safety glasses
Step 3. strike "X" sharply with very large hammer
Step 4. clean up broken glass
Congratulations you have now removed your rear window
:rolling: :rolling:
Sorry, couldn't pass that up.
:rolling: :rolling:
See Darrow. Removing is easy. Now, re-installing is another.:laughing:
great I wil get started soon
yea yea yea and then duct tape and plastic....:huh:
hay bird I will be going to help rich tue or wed or you working.....tim you can come to what flight can you be on.
...........yea yea yea and then duct tape and plastic....
I'll know tomarrow. Maybe under my own. PS control valve went out. Sound familiar?:laughing:
It's not old enough to need "Depends". Therefore, it HAS to be marking territory. It's really doing it on purpose. Just to piss you off.
Done it on 2 1973's that I have owned. There is a post over at CF on how to do it. If needed I can sent you some pictures and a quick write up if you can locate it over
there'.
Roger
I have been thinking about using plexiglass for the window. Drill it for hinges (hinges not determined yet) and hinge it either out (lay on rear deck) or in and have it fold up under the rear deck. Use some thick blub seals with a latch at the top. I would love to do this without using '69 window parts.
Gotta be a way! :thumbsup:
remove
I’ve already got the window out of my 75. I’d like to make it a removable rear window; I have no A/C. I’ll have to go look for that thread.
if you find a removeable window with the hardware it should bolt in as the old holes are still in the body, a couple of us started that last year,,o screwed up my sholder and haven`t been able to do anything,
From your avatar, it's looking like a rear window should be way, way down on your list of things you need..:rolling:
Discussion Starter · #18 ·
But look at the side pipes
If any one finds that post over there see if you can post it here....
1 - 19 of 19 Posts
