I need some help here guys. I've went through and tightened all the rockers both times. It was running great, minus not holding an idle. I tried the relearn procedure and got about 7mi and it started valve clatter. I believe the rockers are coming loose again. Can I use thread locker on it? Will this keep my engine from idling?
thank,
Josh
Your Rockers are to be torqued to 22 ft lbs when they are closed. Yes you can use locktite :thumbsup:
Again, there is no gap to worry about, torque them to 22 ft lbs.
