In that case, it depends on how much you want to spend. Honestly, for street use, you don't need a lot of brakes.
If you just want to get the job done, OEM-style replacement rotors and some OEM-style ceramic pads will work great on the street. Most auto parts stores will have some Brembo blank replacement rotors and they're pretty cheap. The Wagner Thermo-Quiet pads are extremely low dust, quiet, and are effective for street use. Just don't plan on tracking your car with those pads.
For a little bling, you can find some cross drilled/slotted replacement rotors. I don't recommend those for track use, but they sure look cool. If you want a little more stopping power, i've used Hawk HPS pads. As long as you don't mind a little dust, they stop great and are an upgrade to ceramic pads.
From there, the sky's the limit.
P.S. I'm with RTGordon. The big dollar kits are a waste of money if you're just using the car on the street, unless you can justify spending that much on bling.
