The air dam exists to keep air out from under the car (becoming more important as speed increases), and to deflect air toward the cooling system (more efficient as speed increases).
My guess is that at lower speeds, your coolant temp may increase sooner (but probably not much faster), and that you may wind up running the fans a bit longer. It wil also take longer to bring the coolant temperatures down to 195 - 197 when you go from stop and go to highway speeds.
With respect to stock ride heights, you can find that information in the GM Factory Service Manual (sold by Helm - there's a sticky at the beginning of the C4 Tech Section giving links to buying the FSM. The manual tells what the heights are as well as where to take the measurements.
I can take a look in my FSM and see what the ride height is for a '95 - I can't imagine that it would be significantly different.
Steven
