Status
Not open for further replies.
setting up a cam CORRECTLY
FIRST YOULL NEED TO KNOW HOW TO READ A SPEC. CARD, heres a few typical ones
http://www.crower.com/misc/cam_spec/cam_finder.php?part_num=00383&x=52&y=6
http://dab7.cranecams.com/SpecCard/DisplayCatalogCard.asp?PN=114681&B1=Display+Card
http://www.compcams.com/information/search/CamDetails.asp?PartNumber=12-771-8
http://www.cranecams.com/spechowto.htm
things to read, (YEAH SOME IS INFO ON PONTIACS BUT THEY ARE CLOSE ENOUGHT THAT YOULL STILL LEARN!)
read
http://www.newcovenant.com/speedcrafter/tech/camshaft/1.htm
lessons 1-8
http://www.boyleworks.com/ta400/psp/camshaft.html
http://www.jimcookperformance.com/TechNotes/TN6DegCam.html
BUT KEEP IN MIND everyone makes mistakes INCLUDEING THE GUYS MAKING CAMS AND TIMING GEAR SETS and if your like me , for several years I installed cams at the factory marked setup points and only occasionally had engines not run quite as well as I thought they should.
we let me say this , since I started checking things carefully with a dial indicator I find just how sloppy the manufacturers tollerances are and that engines are fairly tollerant of running cams that are ground a few degrees off what the spec card SAYS the SPECS are. but be prepared for a shock at just how loose some manufacturers are at matching the cam to the posted specs.
if your still interested heres instructions and tools priced reasonably
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3292&prmenbr=361
heres just the video if you have the tools already
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=30669&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3293&prmenbr=361
or if you want written instructions
BTW I have both of these degree wheel, the larger 18" moroso wheel is great with the engine on an engine stand but the smaller size is mandatory IN an ENGINE COMPARTMENT
http://www.thedirtforum.com/degree.htm
http://www.hotrodder.com/kwkride/degree.html
good info to know
http://www.symuli.com/vw/camp1.html
http://www.symuli.com/vw/camp2.html
http://www.chevyhiperformance.com/techarticles/95298/
now Im assumeing you did your research and got what both you and your cam company of choice think is the correctly matching cam for your application!
(1) make sure the cam youve installed matches the specs on the card
(2)if after running the engine you feel that moveing the torqur curve up or down in the engines rpm range will be of benefit to you , retarding it tends to move the torrque peak upward about 100rpm for each 2 degrees of retard, (ID stay within 6-7 degrees of the SPLIT OVERLAP POINT BTW) advanceing the cam 2 degrees tends to lower the torque peak s rpm by that same 100rpm for each 2 degrees, if you need to go more than 6-7 degrees YOU REALLY NEED A DIFFERANT CAM
(1)you must always check CLEARANCES
(2) many cams are already ground 4 degs advanced
(3) if you need to advance or retard a cam more that about 7-8 degrees MAX [color:"red"]FROM THE SPLIT OVERLAP POINT you WILL BE way better off with a differant cam
(4) displacement, stroke clearances and rod length ,ETC,DO have an effect on the results
http://www.chevytalk.org/threads/showflat.php?Cat=&Board=UBB64&Number=291865&Forum=UBB64&Words=lifter%20bore&Match=Entire%20Phrase&Searchpage=0&Limit=25&Old=3months&Main=291065&Search=true#Post291865
http://www.cranecams.com/instructions/degreeing/degree.htm
http://www.cranecams.com/instructions/degreeing/degree1.htm
http://www.cranecams.com/instructions/degreeing/degree2.htm
(5) if your in doubt,while picking between two similar cams, always go with slightly lower duration and a wider LSA , you might loose some hp/tq but youll be slightly less likely to get into problems with detonation and bad idle if the specs are very similar
Status
