pulling into a parking spot or backing out I get a popping noise in front end, sometimes even coming to a stop it makes noise. Raised up on rack with tires on rack and checked, turned wheels can't find anything. Thoughts?????? BTW, 2011 grandsport.
As we know, the front suspension of a car has a lot of geometric angles to it, known as the Ackermann System, which has the inner wheel/tire assembly turning 'in' sharper than the outer wheel/tire assembly, the old soldiers marching in a circle routine, to make up for the difference in length of the radius that is formed by those respective wheel positions. It's formally known as 'toe-out on turns', or the 'inclusive angle' and is built into the steering arms; it is a 'non-adjustable' angle.
The wider the wheel base of a car, the more the 'difference needed' in the 'toe-out angle' between the inner and outer wheel/tire assemblies, and vice versa.
Well, our tires are so dang wide on GS, I have one too, near 11" fronts and 13" rears, they could use their own 'toe-out on turns', inner tread-to-outer tread, which is not possible being solid rubber.
On turns, what happens is the tire tread blocks 'bind up', as you turn, and then release, resulting in that popping, or squealing on a very smooth surface, noise you hear. There is nothing that can be done about it, as it is a function and result of front end geometry and very wide tires.
I get the same noise with my Suburban which as 275mm/10.8" width size tires.
Trust this helps.
The wider the track of a car, the more the 'difference needed' in the 'toe-out angle' between the inner and outer wheel/tire assemblies, and vice versa.
Trust this helps.
Trust this helps.
I have this weird issue that's been bugging me this past week. When I'm traveling at low speed (pulling out of my garage, turning from stop, etc.) I hear a popping/clunking sound from the suspension. This happens whenever I turn my wheel either way, usually within the 11-1 wheel location (if the steering wheel is represented as a clock).
I'm not sure what it's coming from and snaptube vidmate I only notice it at low speed. I don't have much experience with car suspensions, but I'm willing to investigate to find a solution.
The popping noise you hear when turning is likely a blown end link ( they have a bolt on each end and are connected by a piece of metal ) . It is really common for these to go out.
How to check your end link - the best way is to take it off and wiggle the bolts - if they have no resistance , it is blown. ( you will be able to tell ) .. FYI - there are four end links .. two front and two back ... all the same part number
