Probably not the right word I guess. I mean when the edges are raised higher than the center, like a meteor crater. I guess I should say the edges are higher than the undamaged pain outside of the chip. So then when you use the blob remover, it doesnt make it as flush so the light can catch it.
I have a ton of small sand rash chips on my rear fender/ brake duct area. I did a few up and it wasn;t bad, but this winter I need to take a day and work it over.
It's not a miracle product, but for what you have it might be worth a try. It will for sure come out better than just touch up paint.
When I did it I had intentions of doing a post with pictures, but it blended in well enough that the stupid camera wouldn't show anything, even though I could see the repair work with my own eyes so I didn't bother making a post since I didn't want to decieve anyone into thinking it was a magic cure.
BTW, with the Langka product, if you screw it up, the blob remover can be used to easily remove your touch up paint and you can try again and again. So really, as long as you have factory paint, you don't have anything to lose but $60.
