well, suspension threads seems to be a dime a dozen around here any more, so I thought I'd add another :laughing:
I'm planning on making some HD struts already, but figure I should make a new bracket while I'm at it to make the most of my improvements. After reading through this 5-link thread it's clear that having the ends of the rods vertically in line with the U-joints will create a parallelogram between the halfshaft and strut rod and thereby will eliminate camber change through suspension travel. However, without modifying the bearing housing on the TA the outer end is fixed.
What is the ideal location (relative to stock) of the inner rod mount to minimize camber change with an otherwise stock suspension?
Here are some very helpful solid models I copied from the 5-link thread:
looks like lowering it 1.5" helps a lot, but shouldn't it move outboard slightly as well?I am still having trouble trying to decide what the amount of camber gain should be over 2 in of suspension travel. For reference here is a stock corvette
And a Smart strut setup. I have droped the strut mount 1-1/2" down.
