121 - 132 of 132 Posts
Discussion Starter #121
from what I have been told by several top name Corvette drag racers is that the C6 Z06 diff is good all day into the 8s and the ZR1 diff is good all day into the 6s. Mark Carlyle makes about 3000hp and runs a glide/ZR1 diff combo. Him and I also talked quite a bit about trans and diff choice and as long as I don't have aspirations of sub 8-sec passes I would be just fine with a built C6 Z06 diff.
He also said that I could take a 4L65 reliably into the 9s with no issues- as long as I didn't want to get into the 8s. Then a 4L80 becomes the better option.
Its a Risk we all choose to take in different paths.
When an IRS part breaks at 140 & you crash into a Retaining Wall.
Or flip over on the roof the other racers will be OK.
Not in the car with you Hardcore.
What do those guys have for race budgets every year ?
Who pays thier Bills to Race ?
Do they race on budgets of $ 2-8k per year ?
What do those C6 ZR1 Diffs cost $ ??
Just 500 bucks ??
Discussion Starter #122
Being a Corvette & Plastic & glass, if it crashes from broken IRS parts failing will the body survive with Metal Creases & dents only ???
Discussion Starter #123
I Don't Care What Other Mother Ass ****ers Do.
They can Rub thier Cocks All Over a Corvette IRS They Want & Squirt Thier Spooge on it.
I think its ****.
Grumpy Does too.
I can get a C6 diff and fully build it for about $2500. A ZR1 diff for about $3000. Going solid axle is going to cost at least $10,000 given the new custom rear cradle, suspension, and possible frame modifications.
I do appreciate your help, but there is just no way in hell I will be able to afford a solid axle conversion in the next 5 years as I will still need to do trans and **** on top of it.
My goal for this car is 9s as my DD, if I can do it reliably for a $2500 diff and $3500 trans as opposed to a $10,000 diff and a $3500 trans that is by far the option I have no choice but to take.
I know I am giving up some et and mph, but this isn't a pro drag car, it is the car I drive every day, every where.
Discussion Starter #125
There are just a hanfull of Real Mechanics Left.
Your 1 of them Too Hardcore .
I am showing you step by step to do it yourself .
You can pull it off for $5k or under.
Think outside the box.
Sidejobs fund our Race Habit $$.
I am at around $2k only now.
Not including other 5 1957-58 Pontiac Olds rears I bought & Grumpys Dana 60 Rear 4.10 Posi.
Discussion Starter #126
I thought we would take a look at main drive shaft options.
It applies to all C4 owners & C5 owners that choose a Conventional Engine Drivetrain layout over the Torque Tube assembly.
The stock C4 main drive shaft is aluminum. Thin wall design.
No way it will hold up long term to extreme shock loads of 5,000 RPM Launches & HP 600- 3,000 like modern drag cars have.
Mild steel, Chrome Moly Steel, Thicker wall aluminum alloy,
Carbon Fiber, & even Titanium tubing driveshafts are available custom made.
I will eventual need a custom drive shaft for my Solid axle 4-Link project. I would not use the stock shaft even it does fit. Safety issue.
VIEW CART 0 Products ($0.00) CHECKOUT
Orders Only
1-800-955-1872
Questions
1-716-875-6640
Denny's Driveshaft builds custom steel and aluminum driveshafts for your high performance car, street rod, race car, van, pick up or 4x4 truck
Measuring Diagrams
How to Measure Correctly
Driveshafts
1350 Nitrous Ready Driveshafts Heavy Duty Driveshafts Aluminum 6061-T6 Driveshafts Street Rod Driveshafts Cobra Kit Car Driveshafts 4x4 and 2WD TRUCK Driveshafts
Driveline Parts
AXLES and Front End Parts - 4x4 BALL JOINTS - 4x4 BEARINGS - Center Support CLOTHING - T Shirts CV - BALL STUD YOKES CV PARTS - Double Cardan ALL FLANGE YOKES GEARS - Ring and Pinion Sets HARDWARE - U-Bolts, Nuts more LUBRICANTS - Grease PARTS - ALL Driveshaft and Driveline PINION YOKES FRONT/ REAR END PTO PARTS - Power Take Off and AG RUBBER BOOTS - Slip Yoke SEALS SEALS - Slip Yoke Dust Caps SLIP YOKES - Driveshaft SLIP YOKES - Transfer Case SLIP YOKES - Transmission SPINDLE NUTS and WASHERS SPLINES TRANSFER CASE YOKES - BOLT ON TUBING - DRIVESHAFT UNIVERSAL JOINTS UNIVERSAL JOINTS - HEAVY TRUCK WELD YOKES - TUBE YOKES
Shop By Vehicle Type
CHEVROLET BUICK PONTIAC OLDSMOBILE DODGE PLYMOUTH CHRYSLER FORD MERCURY LINCOLN JEEP
Customer Testimonials
I have had a Denny's Driveshaft in my Cobra Kit Car for over a year now and have not had any problems. It handles all the HP I can give it!!!
...read more
Michael W ~ Yates City , IL
Payment Processing
1350 SERIES...Denny's Nitrous Ready Driveshafts
  • This is our STRONGEST and BEST DRIVESHAFT ... custom built specifically for the most SERIOUS STREET and RACING applications.
  • HIGH SPEED - HIGH RPM BALANCED and TESTED for the ultimate in smooth running operation throughout your FULL RPM RANGE and at all road and track speeds
  • If you ever twist the tube or break a weld.... Replacement is FREE! Strength and Reliability you can count on...Start to Finish!
1350 Series = Total Driveline Reliability
...with or without nitrous
It's Easy to ORDER one NOW!
TO ORDER: Please measure using ONE of the following Measuring Diagrams.
AFTER you have measured:
PLEASE CALL
1-800-955-1872 to PLACE YOUR ORDER
ORDER ANYTIME ONLINE by CLICKING on the choices below
Please call us with your dimensions after you place your order online​
1350 SERIES 3 inch Nitrous Ready Driveshaft
CLICK HERE for More Details Part#: NR-3 $485.95
1350 SERIES 3.5 inch Nitrous Ready Driveshaft
CLICK HERE for More Details Part#: NR-3.5 $520.95
1350 SERIES DRIVESHAFT 3 inch Nitrous Ready with CHROME MOLY SLIP YOKE
CLICK HERE for More Details Part#: NR-3CM $630.95
1350 SERIES DRIVESHAFT 3.5 inch Nitrous Ready with CHROME MOLY SLIP YOKE
CLICK HERE for More Details Part#: NR-3.5CM $665.95
1350 SERIES 3 inch Nitrous Ready Driveshaft PRO PACKAGE
CLICK HERE for More Details Part#: NR-3PRO $765.95
1350 SERIES 3.5 inch Nitrous Ready Driveshaft PRO PACKAGE
CLICK HERE for More Details Part#: NR-3.5PRO $791.95
DENNY'S NITROUS READY is our STRONGEST and BEST DRIVESHAFT assembly. We call this one NITROUS READY because it was specifically designed to handle the massive power generated by using a bottle. This is the ORIGINAL Nitrous Ready Driveshaft... not one of those so called copies that you will find out there with a similar name. Beware of imitations!!!
Racers worldwide have proven the legendary benefits of this shaft in all out racing competition. It’s at home on the street and at the race track. You can choose from 3 inch, 3.5 inch tubing and they come complete with 1350 SERIES transmission slip yoke and solid body u-joints or we can build it with your own1350 series slip yoke if you already have one.
We build this shaft to do what it takes to keep it all together, especially if you are using Nitrous, a manual transmission or have a heavyweight vehicle. This driveshaft will deliver the power to the rear end smoothly and reliably whether your racing is on the street or at the drag strip.
IF YOU EVER TWIST THIS TUBING OR BREAK OUR WELDS...WE WILL REPLACE THE ENTIRE DRIVESHAFT FOR FREE.
Nitrous is not the only reason for owning the best. For those of you who require the ULTIMATE STRENGTH and RELIABILITY from your race car driveline ...THIS IS IT.
With this shaft you will be able to run with confidence knowing that it will deliver all that horsepower and torque to the rear end smoothly and efficiently without the worry of breakage or the loss of valuable time due to vibration. Vibrations slow you down and destroy more parts than you can imagine. We all know that anything that vibrates is really annoying...especially on the street.
Built with the virtually indestructable 1350 series components for super long life and trouble free operation. Also if you are planning on adding more horsepower or traction in the future this shaft is the best choice. You won't need to buy another shaft later.
Each shaft is built with meticulous attention to detail. Each shaft is HIGH SPEED - HIGH RPM BALANCED then TESTED on special equipment to be sure it will run the rpm that you require. If it does not pass this test it doesn't get shipped out. No guess work here...we know what it will do for you because of this final test. That is why a DENNY'S DRIVESHAFT will perform BEST in your street car or race car application.
All NITROUS READY racing driveshafts come with our FREE LIFETIME LABOR for most any maintenance or alterations needs. Please see the LIFETIME LABOR section for details.
You may find MORE INFO and PRICING about our NITROUS READY DRIVESHAFTS for your specific car or truck by clicking on the appropriate LINK at the TOP or BOTTOM of this page
Buick Chevrolet Chrysler Dodge Ford Driveshafts and Driveline Parts Jeep
Lincoln Mercury Oldsmobile Plymouth Pontiac
Privacy Policy & Disclaimer
Call
Send SMS
Add to Skype
You'll need Skype CreditFree via Skype
Discussion Starter #127
Toll Free:
1-866-508-6394
Local:
303-665-6901
Fax: 303-665-7021
Order a Catalog
Products
TechnicalWhat's NewServicesCustom WorkIn the NewsFor SaleIndustrial ServicesContact UsCatalog
Shopping Cart: 0 Items In Cart Total: $0.00
Checkout
Advanced Search Click Here to sign up to receive discounts and news on our latest products.
COMPARING VARIOUS MARK WILLIAMS DRIVESHAFTS
Type MasterLine MasterLine Mild Steel Chromoly Gold-Fusion Accu-bond Accu-bond Carbon Fiber Material DOM
Mild Steel 6061-T6
Aluminum DOM
Mild Steel 4130
Chromoly 6061-T6 Aluminum 7075
Aluminum 6061-T6
Aluminum
Carbon Fiber Sizes 3" x .083" 3.5" x .125"
4" x .125" 3.5 x .065"
4 x .083" 3" x .083"
3.5" x .083"
(1350 & 1480) 3.5 x .125"
4 x .125" 3.5" x .110"
4" x .100"
(1350 & 1480) 3.5" x .125"
4" x .125" 3.750" x .120" Finish Black Paint Natural black paint Blue Paint Gold
Chromate Gold
Chromate Gold
Chromate Natural End
Yokes Spicer 6061-T6 Spicer MW 4130 6061-T6 MW 7075 MW 7075 MW 7075 Attachment welded welded welded welded welded Accu-bond Accu-bond Accu-bond U-joint 1350 1350 1350 1350 & 1480 1350 1350 & 1480 1350 1350 Trans Yoke included included not ncluded not ncluded not ncluded not ncluded not ncluded not ncluded SFI 43.1 No No No Yes No Yes Yes Yes Part No(s) ML-600 ML-39200
ML-39300
39650
39640 39800
39850
39880 (1480) 39940
39945 39555
39550
39890 (1480) 39985
39990 39100 Price: $520.00 $600.00
$648.00 $390.00
$405.00 $429.00
$488.00
$555.00 $600.00
$606.00 $815.00
$826.62
$1,100.00 $559.00
$579.00 $1,034.00 Prices include driveshaft, U-joints and balancing.
Why It Pays To Invest In An M-W Driveshaft
Driveshaft and Ordering Info
Technical Information about driveshafts Browse Driveshafts
Call
Send SMS
Add to Skype
Discussion Starter #128
Next Previous
Tubular Driveshafts
3 1/2" Chrome-moly driveshaft with Strange forged 1350 weld-ends & heavy duty u-joints.
$415.00
Part Number: U1704
3 1/2" OD X .083 wall 4130 steel. Fully TIG welded and balanced with forged chrome-moly weld ends and 1350 series u-joints.
*Transmission yoke not included.
Discussion Starter #130
What is hard to believe,
The Ford 5.0 guys can walk into their local dealership, laydown $160 cash & buy A Ford Motorsport Aluminum Driveshaft( U-joints & Yoke included assembled) that is good for 1400 HP, 5,000 RPM starting line Launches Dead Hooking 1.1-1.3 60' Foot times, Rear bumper dragging & Front end in the air, 8- second runs.
I have been there at the tracks & in Pits & garages at night helping.
WTF GM ????
I will likely use a Strange Chromemoly or Denny's Nitrous driveshaft.
Mark Williams is Exotic. $$$.
There is no feasible way to move the transmission to the front of the car. There is barely room for the bellhousing.
Discussion Starter #132
The Moser 12 C5 kit moves the trans to the rear of the engine. Up front.
Must be room.
Its just glass.
Cut it. Repatch it up with glass & resin.
RACE CAR.
Not dead slow show & shine do nothing.
What do you think every drag racer does ????
Bolt on **** is gay.
