well i posted a few days ago and never got a response about the spark plugs, but i replaced the opti with msd, the coil with msd, and the plugwires with msd. i am replacing the plugs with ngk g-power with the parts store says that these plugs need to be set at .050'' with this engine. now with that new msd set up i got what should i set them at?, i was thinking .042'' cause thats what my father told me to run. also the only reponsewas fsm said .032''
kinda lost need info please
Assuming that all is pretty much stock internally I'd run .045-.050. If you are running forced induction you need more current and voltage to jump the gap as boost pressure goes up so you would needto run a smaller gap somewhere around .035-.040
