On the starting in between P/R you need to adjust the neutral safety switch. Typically you loosen the mounting screws, put in neutral, slide the switch gently until you can insert a small paper clip in the hole in the center of the switch then retighten the switch. That should line up Park/Neutral as the start locations.Have you had your ignition switch out column out recently? Could have some wires mixed up. Maybe some one else will chime in too.
BTW welcome to digitalcorvettes:buhbye:
wiring
It would be hard to get the ignition switched around to start on accessory... most of the switch units come so that things only fit one way. Unless the wiring has been switched someplace after the switch mechanism but before the starter. I would try tracing wires.
Re: wiring
rgevers04, welcome to digitalcorvettes! Glad you found us. :thumbsup:
