Now I have another problem. They never seem to end. My horn won't work with the button. I've replaced all the components associated w/this in the column. The tail, front parking, brake and blinker lights all work, but the hazzard lights only work in the front! If I turn on the hazzard lights and put the turn signal switch in either position, the front hazzards both work but only the side the blinker is switched to in the rear. Also sometimes if I jiggle the hazzard switch, the horn works. I've checked the wiring to the horn relay and it is good. Also I put in a new relay. I can't seem to figure out how to get into the steering column to access the turn signal switch!! Does anybody know where I can find directions on how to disassemble the column? My assembly manual doesn't even go there. I figure while I'm in there I'll tighten up the tilt-tele mechanism too. Sorry for the long thread but I'm frustrated at this point!!!:huh:
