If you are going to be pulling and re-installing the slave cylinder yourself, you should consider rebuilding it yourself. Rebuild kits are available at reasonable prices, and step-by-step instructions are plentiful on the net. Pull the cylinder, disassemble and check the condition of the parts. If it looks good, you can buy a rebuild kit, needed tools (snap ring pliers etc) and paint for less than you'd spend on a reman. You'll know it's done right, plus you can use the tools and paint again. I just did this as part of a front suspension rebuild and it is not complicated. My 2c
