I'm putting the Vbp powersteering conversion kit on a '68. after I removed the pitman arm I realized I messed up. I didnt center the steering wheel. I centered the wheel acording to the stops in the box. will this be centered on reassembly? I just dont want to take everything back apart.
Thanks!
Thanks!
Should be fine. More than likely you would have move the steering a bit removing the pitman arm anyway.
Just double check your centers as you progress with the installation, making sure everything is still straight and centered.
Trust me everything will move a lot as you install the parts.
Thanks guys! I thought I was is Trouble!!
