I'm adding a 10" sub in the back and needing to add a mono amp. I have a 2007 with OEM radio/CD player with XM radio. I have some questions on the wiring:
1. Which wire should I use for the remote/power on for the amp? Location and color would be helpful. Does the XM radio box in the back drivers side have a remote wire or do I need to pull from the stereo?
2. Which speaker output should I use to run the amp and should I pull from the stereo output or the stock amp output to run as the input to the mono amp?
Thanks!
