1 - 9 of 9 Posts
I currently have the louvered covers on the tail lights. I do not want those on there. Is there an easy way to replace the tail light lenses since they now have screw holes in them?:cheers:
If you consider an easy way to destroy your hands and arm through the licence plate hole to reach screws from behind...that's the easy way:laughing::laughing:
Sorry bro, just listen a lot of guys talking about this boring job,never done ,but i think if you put an hand using your fingers you can recognize what kind, i think you have to remove the first lense near the plate,then you can use the lense housing hole to reach the next
Easyer way kinda. this will keep most of the skin on your hands.
Remove the rear tires and inner fenders and use a socket and extention you can get to the outboard lens easy the inboard one just reach though the outboard lens hole to get to them.
They are 10mm all you need is a 1/4" drive rachet. Once you break them loose you can use the socket in your fingers.
1 - 9 of 9 Posts
