Yep I do mine by myself all the time. You have (should have) a wrench in the car. It's a torx bit. You loosen the two screws in the windshield header, those screws will stay in the header, then in the back brace of the top there are two more screws. These will come out so place them in the cup area where your power seat controls are. Pop your hatch and lift the front of the top up and tilt it back you can then get the back with your free hand. The top goes into the hatch area rear first. Each side of the back of the top will fit into the brackets in the hatch. Lower the front and you will see a hole in the front of the top that lines up with the nipple in the hatch pull the little handle and lower the top all the way, go cruisin with some top off fun.:thumbsup:
Aight have to check it out. Do you have a picture of what it looks like with the top in the hatch area?:huh:
