i have installed a zz4 and i wat to confirt to eletric fans
the problem is the orginal temp gauge may not work
how can i test it
also the old sending unit threads are different
how can i test it
Temp gauge is a temp gauge, not going to change on account of fans...
but that sending unit problem is identical to mine in that I forgot to get the #113 aluminum heads machined for the old gauge...I went and changed the resistors across the gauge to correspond to a Ford truck sender '99 5 liter, as I recall....
The values I used for the resistors, I have posted about in the past....but forgot what they are, have to go check, I just played around untill the important parts of the range were pretty accurate....
because orginal temp sending unit thread problem i installed remote gauge pod and used last manfold port for new gauge
where will i put eletric fan temp probe
Dunno about the temp probe, what it takes size wise, but the two intakes I have to look at one is a performer edel, the other is GM aluminim..I see many holes into the front crossover...more in the Gm than the Edel...
wonder if you have a probe meant to go into the radiator fins?? some do,...
another way is to slide it up into the upper hose, near the radiator, seal the tube with a dap of RTV, and clamp hose around it...sneak it over to switch controller....
