OK... today's advendture on I95:
It was very hot today and my engine temp went up to roughly 225F. Normally it doesn't go above 210F (center mark on the gauge) but today I had to turn the AC off so that the temp stays at 210F.....
Well, I turned the AC on and off as the engine temperature allowed, it went up to 225 a few times and then back to 200-210 when I turned the AC off and slowed down to reduce engine rpm....
I noticed that my oil pressure was only 50psi today, normally it's 60 and higher. Usually it's 40psi at idle, today when pulling into a gas station I noticed it's 30psi at idle :crazy:
I let the engine cool down and checked oil pressure: now it's back to normal, 40 at idle and 60 when driving.
I changed my oil about 4 weeks ago. castrol synthetic blend 5W30 was on sale - it was a good deal and I bought it instead of the 10W40 that I usually use (Castrol or Valvoline synth blend) .....
Now my questions:
Is 5W30 too thin at 225F engine/water temperature ?
Should I be worried ?? Engine runs fine now that it's cooler... I went back on the highway and the temp didn't exceed 210F....
Now my questions:
