1 - 20 of 22 Posts
About to order a new cam to stuff in my base 81 before I put all the engine periferals and front end back together. Easier now than later and I want a little more out it than I had. This is the cam kit I am looking at.
http://store.summitracing.com/partdetail.asp?part=CCA-CL12-242-2&autoview=sku
This is temporary, once the car is all back together and on the road I will do a full engine rebuild with a roller conversion kit, more aggressive cam and AFR heads. For now, I am keeping the stock carb, computer, dizzy and adding an Air Gap manifold. I have removed most of the smog stuff and adding headers and true duals, no cat
thoughts?
Danny,
If your going to do it over later, don't over cam it with that computer stuff. Just put in a GM151, and be done with it.
Don't know that cam, not planning on going nuts. The other guys are recommending a summit 1103.
I just want to give it a bit more snap once its running while I finish the body work and paint and all that. The last piece will be the engine
Danny,
:agree:
Just about everything over a base cam is going to cost more. If you go too much more you'll need springs too. A cam and a set of lifters can be inexpensive. Then add a set of springs and the price goes up. And unless you are really good (or lucky), the new and final choice of cams will require different springs. My past experiences tell me to use matched sets from whatever manufacturer. Cam, lifters and springs all designed to work together instead of just selecting parts based on what's in the "recommended" column in the catalog.
ITS $100 CHEAPER BECAUSE its JUST the cam , the crane deal INCLUDES THE LIFTERS, and its a better made cam, not a generic
compare apples to apples
http://store.summitracing.com/partdetail.asp?part=SUM-1103&autoview=sku
http://store.summitracing.com/partdetail.asp?part=CRN-114132&autoview=sku
add the lifters to make it a compareable deal,
http://store.summitracing.com/partdetail.asp?part=CCA-812-16
personally ID think it foolish to NOT go with a match set with better quality parts for that differance, especially since youll have BOTH summit and CRANE CAMS, as potential warranty sources vs only summit if it screws up
and your only at about $28 differance
My thoughts
The cam Grumpy selected shows computer compatable.
The one Danny and you selected shows non-computer compatable.
16 lifters for $10? You don't have to be a rocket scientist to figure that one out.Taiwan/China/Yugoslavia
My 2 cents
My thoughts
My 2 cents
China.... that's where all this stuff comes from, incl name brand stuff. You don't think a camshaft/lifter kit for $200 is made here in the US ????
Danny said he's removing his smog stuff and installs dual exhaust with headers, didn't think the cam has to be computer or emission compatible....
I told him yesterday that I would just stick the old one back in that block and call it good until he's rebuilding the engine with roller cam and better heads.... safes him some money and the aggrevation of a cam break-in....
Danny is keeping the computer carb/dizzy/ecm. Don't ask me why. If Ca. law let me, that crap would be gone. Hello 502.:rolling:
Discussion Starter · #15 ·
OK, so today I drop the hammer on this order:
I am concidering the GMPP cam Grumpy suggests. Looking at everything I see in here, it seems that although the Summit package is cheaper it is sortof unknown parts. Summits Crane Cam is more in the line with the GMPP cam pricewise. The GMPP cam will run well with my stock heads and pistons? Final comments?
It looks like either way I will need a new distributor gear corect?
EDIT: I see BB recommended the GMPP and Grumpy sez Crane, and BB agrees...
Discussion Starter · #16 ·
Order placed for Crane Cam kit, Endurashine Edlebrock Air Gap intake, one piece oil pan gasket and 2 piece timing chain cover kit.
Ouch
A jig saw will make the intake fit.
I tried that 2 part timing cover thing in my younger days. Would have been great if it hadn't leaked. Good luck.
And good choice on the cam too.
Discussion Starter · #20 ·
Air gap? Have you checked your hood clearance for that Danny?
Nope, but there is an L88 hood in the plans. Imagine the surprise and disapointment when I have to tell the GF, "Honey, guess what, my hood won't fit now, I guess I have to get a different one"
think it will fly?
1 - 20 of 22 Posts
