1 - 8 of 8 Posts
LOL, you said Modern and BoltUp in the same paragraph.
Boltup = TH350, TH400, TH2004R, TH700R
Modern = 4L60E, 4L80E and whatever is in the new vettes
Boltup is in the eye of the wrench holder
What do you want to do, what do you want to spend?
I've seen a post from someone putting a 4L80e in a Vette somewhere. The physical size of the tranny was going to require some floorpan mods. I'm sorry I don't recall where it was I saw it. Is there a 6 speed auto that would have a chance of fitting? I've got an Allison 5 speed in my truck, and that thing is HUGE- especially when you start looking at the tunnel on a C3. And they do come in a 6 speed. The 4L80e has a lot of torque capacity, AND a lockup convertor, but they're pretty heavy too.
I was thinking of mating to the engine eng with an adaptor or the like in the worse case.
On the other end I would cut/weld the shaft to fit.
The transmission supports and stuff not a big deal.
My budget was around 2500$
On a side note it would be great if I could use the same transmission on a future LS3 crate I had planned down the road
http://store.summitracing.com/partdetail.asp?part=NAL%2D17802134&autoview=sku.
I'm pretty sure this is wishfull thinking. I have a 700R I may rebuild as a backup plan. I was wanting a lil better fuel milage for trips. I am now just getting the beast road worthy but am eyeing future improvements.
Most of the tricky wrench work is done by my step-dad and I'm there for parts funding and easy stuff.
A $2500 budget should be an easy fit for a bumped up 700.
Ebay can get you the rebuild kit for around $250
Shift kit annother $150 or so
SOme other hot rod parts for the inside annother couple hundred
Torq Converter $200
you got fab skills and tools, custom crossmember ~$50
Get the drive shaft cut to fit and balanced, don't know the $ for that.
you can easily do this part for under $1000
Tranny not that hard to rebuild, I just did mine with a book and a video.
1 - 8 of 8 Posts
