· Premium Member
There could be lots of things causeing that but most I think would throw more codes. pluged injectors, low fuel pressure, bad O2 sensors, manifold air leaks, ect. have you did any thing to the intake or exaust system. or other mods?
· DC PIT CREW BOSS
I get these code periodically. It seems to happen after a lot of very spirited driving or some hard passes at the strip. They pop up 1-2 times a year. I clear them and usually ofrget about them til it happens again
Thanks for the help
thanks for the info guys, cleared the codes this morning and they havent come back hopefully it stays that way. I also have cold air intake and borla stringers so im guessing that was the problem
I'm getting the EXACT same thing out of the blue for the past week. Usually happens ONLY a few minutes after starting her up and idling around the streets.
Car isn't even at full operating temps when this does occur which leads me to believe it may have something to do with the O2 sensor ???
I've cleared the codes 3-4 times now over the past week and a half and the SAME TWO codes P0171H and P0174 keep coming back. Sometimes one at a time and other times both at the same time. :huh:
· Premium Member
Any mods to your Vette?
