1 - 8 of 8 Posts
Build sheets (stuck to the gastank) didn't come into use until the '67 model yesr.
The purpose of the build sheet was to identify all of the required options to the assembly line workers, hence it's placement on the fuel tank, which was the only relatively large flat surface on the vehicle on the assembly line until the body was put on. At that point, all the optional bits were already hung on the car, so covering up the build sheet wasn't a problem.
Rumor has it that there was usually a second copy with the body (would make sense) and that some original owners have found these stuck up behind the dash, etc.
My 2 cents
:D :D
DC Pit Crew
interesting :)
There's also one stuck in your frame, but its a bitch to get out.;)
cavsvet74 said:
How did you find that?:huh:
Learned about it on another forum.;)
1 - 8 of 8 Posts
