So I hop in the vette last night to cruise to work... Starts just FINE! Pull right out of the garage! But... I forgot my sun glasses in the house so I go back inside! By the time I come back outside (30 seconds later) the car was off...? Go to start her back up... No go... Push her back into the garage and have to take my beater :(
SOOOO I havent gotten to diagnosing anything yet but I have a hunch that my fuel pump toook a pooper :devil:!
Should I just replace the pump with an OTC unit or should I upgrade and go aftermarket?
Thanks! :buhbye:
I have used both the OE and Airtex with good results. I think Airtex may produce the OE unit and AC-Delco repackages it. (but dont hold me to it) Fuel pump fuse good?? Fuel Pressure?? Fuel pump run at key-up??
Pardon me if this seems too obvious but.... Does the gauge work? I would start by checking things like fuel level, pressure, and relay like mentioned. :thumbsup:
IF YOUR LOOKING TO JUST REPLACE A DEFECTIVE PUMP ILL OUTLINE THE BASIC STEPS
http://forum.grumpysperformance.com/viewtopic.php?f=32&t=33
first check your shop manual for the fuse and fuse able link locations
fuses are located in several locations and fuse-able links near the battery
read thru these threads and links above also, as theres a good deal more related info in those threads and links
obviously the first step is PROVING its the FUEL PUMP ITSELF THAT NEEDS REPLACEMENT AND NOT A FUSE OR RELAY OR SENSOR SO READ THRU THESE SUB LINKS, and DO A FEW TESTS BEFORE JUST ASSUMING ITS A DEFECTIVE FUEL PUMP
Ive used Walbro in my Toyota Pickup (supercharged) and in my Vette. The ones I have are 255 litres per hr and cost me around 60$ each.
Thanks! :buhbye:
How many miles are on this fuel pump ?
Add a direct 12volts with a ground to the fuel pump to see if it kick's-on or not
After you check the obvious of course
I'm not going to tell you my "Gas Story" lol
Discussion Starter #7
Discussion Starter #9
I know man.... AHHHHH it never ends with this thing!!!!! Ive maybe only put 1000 miles on it since the trans.... Now the frigger wont start!!!! AHHHHHH!!!!!!!:huh:
Bro I just went through this with my car
Car started and then died
I began reading all the crap on the internet and nothing,
Then I thought Hey
You need to begin diagnosing this The Old way:nuts:
And sure enough I had it fixed in an hour,
Mann Was I was thrilled to have my car running again
Long story short my wire harness had pulled loose somehow and the fuel pump was not getting enough voltage
It will be OK once you get thru this silly crap. I went thru it on my old 85.:thumbsup:
