Wow! does'nt seem to be as challenging as I thought. Thanks guys...The aftermarket side screens are typically installed with 3M double sided tape. For the side screens all you have to do is cut your wheel hard to one side. You then will have access to the wheel well panel there are 3 screws that you take out. You can then reach your had inside and place the screen over the hole in the fender. You can attach a couple pieces of wire to the screen so that you have something to pull the screen tight to the fender while the tape sets up. The front screens were done in pretty much the same manner. An RTV silicone would work in place of the tapw
I'l will take you up on that NVLAV8TOR...Stop whining....I'll help you.:laughing:
I had to pull the wheel well cover to get at my computer and the vents are right there. You'll see once you get into it that it's probably not that big of a deal. Just remeber "righty-tighty, lefty-loosey" and where you took everything off of. Then reverse and you're done.:smack
Thanks 97 VETTEMAN...Im hopeing to get them in tomorrow.I just did mine it took about 3/4 of an hour, as was said just turn the wheel to one side. My intructions said remove the wheel but I never bothered.
The screens just stick in with 3m tape. Be praped for scratched forearms as it's tricky get to all the bolts that hold the wheel covers on. once you remove the 2 screws that hold the side vent cover in just push the cover aside and put the screen in through the vent hole and put your other hand in from the wheel side. Postion it right so it covers the whole on the apperture and stick down that's it.
Put the plastic covers back and look at your scratched to f--k forarms :laughing: and admire you tuff new look screens!artyon:
:rolling:DAMN! Patrick you better watch your bloodpressure! :surprised
I think I don't use that much salt in my entire 40 years... that you have on your side vent...:laughing:I'm taking mine off I think, all they do is fill with salt.
Screens look great. I put mine in this past Saturday and your absolutely right my forearms are tore up, but I was well worth it, gives the car a clean look. :thumbsup:I took a pic of mine!
